Results 1 to 10 of 21
Thread: Progress Report on my Renault Ondine in Bolivia
Hybrid View
Previous Post Previous Post   Next Post Next Post
  1. #1
    Join Date
    Jul 2011
    Location
    Tarija, Bolivia
    Posts
    30
    Default Progress Report on my Renault Ondine in Bolivia
    In the 41 days I've spent in Tarija where I play with my car projects in my spare time I've managed to get a few things done.
    This is the way it started a year ago.
    Just one front seat
    After a little cleaning
  2. #2
    Join Date
    Jul 2011
    Location
    Tarija, Bolivia
    Posts
    30
    Default
    Continued.....
    Bearings weren't real good
    Nor the A-frames
    Since it had been sitting down in the mud for 20+ years, the brakes were stuck and rusted
    After sandblasting and straightening, it was time to paint the suspension
    A little help from a local machine shop to fabricate the eccentrics and bushings for the steering.
  3. #3
    Join Date
    Jul 2011
    Location
    Tarija, Bolivia
    Posts
    30
    Default
    continued....
    Then one Saturday morning I called a neighbor and wrapped a fire hose around the engine and we pulled it.
    Water pump and whole insides rusted away
    And the block cracked and welded along the side, but the bridge between cylinders 2 and 3 was also cracked, causing elongation of the sleeves. and scraping of the pistons.
    So the block is now welded
    Another evening after work I pulled the rear suspension
  4. #4
    Join Date
    Jul 2011
    Location
    Tarija, Bolivia
    Posts
    30
    Default
    continued....
    Transmission oil was more like molasses with rust on the lower parts.
    Engine support cracked
    So after more welding, it was time to protect the soon to be restored parts.
    Time to rectify some transmission teeth and assemble it.
    Then clean up the manifolds
    And the rear grill
    There are more pics on my site. I hope to get back the end of May to do a little more. Still need a few parts that should be coming from Argentina soon.
  5. #5
    Join Date
    Jun 2009
    Location
    Monterrey, Mexico
    Posts
    522
    Thumbs up
    Congratulations for the great job done with this car!
    Fernando Zavala
    Alliance 1985 Limited
    Encore 1986 GS
    Encore 1986 Electronic
    http://www.kioscomusical.com
  6. #6
    Join Date
    Jul 2011
    Location
    Tarija, Bolivia
    Posts
    30
    Default
    I got back to Tarija and have managed to steal some time to work on the car. Actually got a little don a few months ago that are on my site, although I never got around to posting them here.
    I got most of the electrical parts I'll need to convert to 12 volt, plus the steering wheel, light controls, water pump and thermostat, rack & pinion, and cylinder sleeve to replace the one that was not salvageable. Plus some more.
    I cleaned up the cylinders and the pistons, found that when it had been put together 20+ years ago (although never driven much) one of the oil rings was missing a piece, so had to order rings. Here are a few pics. lots more on my site in month 14 and 18.
    Polished up the alternator
    honed the sleeve
    Pulled the stainless roof trim and started taking out dents and polishing (details on my site)
    Now I'm back and took the shell to the body shop to patch the undercarriage while I assemble the engine and power train. Hope to be able to install it all before I go back to Santa Cruz at the end of the month.
    First shot shows the installation of the stainless water tube I had made
    Then the engine parts and assembly
    Still have a ways to go, but I'll keep my site updated as I go these next couple of weeks
    http://www.widman.biz/Dauphine/English/index.html
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
