Results 1 to 3 of 3
Thread: R17 Gordini and TL differences
    Sep 2014
    Calgary AB
    35
    Default R17 Gordini and TL differences
    Hi All,
    I've currently got a 1974 R17 Gordini (1323) that I want to restore, it's quite rusty and missing a bit. I have chance to get a 1974 R7 TL in fairly good shape. I'm considering using it a a donor, does anyone know how different the body and trim is between the two? i.e. will a TL hood & fenders fit a TS/Gordini?
    Thanks
    Mike
    Jan 2012
    Boulder, CO
    227
    Hi Mike,
    So sorry I know I had missed an email of yours and then just saw the post.
    The parts are the same between cars, its all in the engine, transmission, and other things, but in regards to the body, feel safe buying her as a donor as far as compatability.
    I hope this helps.
    Best of luck!!
    Steve
    Jun 2015
    Drunen, the Netherlands
    6
    Hi Mike,
    Only thing on the body that is different between a TL and a TS/Gordini is the gearbox hump in the floor of the car.
    That's if the American R17 TL's had a 4 speed gearbox, if it's an automatic then the hump is even bigger then the 5 speed gearbox hump.
    The rest of the body is the same.
    Greetings Sebastian.
