When the ignition is engaged, my Ducellier starter makes an awful banging noise. It does spin the flywheel and eventually the car starts but it sounds bad. I stripped the starter apart to check the solenoid. It appears to engage properly. Has anyone had this issue? Is it possible that the solenoid is pushing the pinion too far? Is it possible to adjust the solenoid or just replace it? Thanks in advance!!!
