Results 1 to 7 of 7
Thread: 1987 gta mods/tuning?
  1. #1
    Join Date
    Aug 2017
    Posts
    5
    Default 1987 gta mods/tuning?
    Hey everyone thanks for letting me into your club I'm pretty new to the Renault scene and don't know squat I came across a 1987 gta convertible and I'm just wondering if anybody knows some mods or running tricks for the f3r 2.0 8v motor also what size tires can be run on a gta/alliance thanks again and look forward to the replies!!!
  2. #2
    Join Date
    Nov 2015
    Posts
    11
    Default
    TACOCAT -
    Greetings - from a also (relatively) new user.
    I have a GTA 2.0L engine and am also looking for performance improvements. I expect it will be a big improvement over the 1.7L F3N I had in my racecar. I'm putting on the headers from the 1.7 - and will start with the Weber 32/34 carb that was also on the it. The next step will be to fabricate a new intake manifold for dual Weber DCOEs. More fuel/air has to be good - yes?
    I expect timing will be a BIG improvement and so I got an electronic ignition system with a crank trigger. I've read that the engine comes alive at 30-ish degrees advance - but the RENIX limits to 20 something. My racecar runs 13 inch tires - but I seem to recall seeing 15s on the Alliance/GTA - in the Chilton's manual.
    After those mods, it would be interior work I'm afraid. Finding a cam, etc - will be expensive and more European connections.
    To improve the shifting, there is a fellow in Hungary, that manufactures/resells a Quickshift kit. The piece replaces the linkage on the transmission for shorter shift throw. He also has some bits for the interior shift mechanism too.
    As I learn more I'll post.
    Cheers - Jim
  3. #3
    Join Date
    Nov 2015
    Posts
    11
    Default
    Just realized I didn't add the link... Not associated - just pleased with his product(s) and I've found him very supportive of the "lost" USA Renault cousins...
    http://www.dp-automotive.hu/dpa_developments.html
    Cheers - Jim
  4. #4
    Join Date
    Aug 2017
    Posts
    5
    Default
    WOW thanks a ton I'll look into all of these things and see what I can come up with any chance you know where to get 1.7l headers and also where you got your crack shaft trigger for your electronic ignition?
  5. #5
    Join Date
    Nov 2015
    Posts
    11
    Default
    Got the electronic ign. from an outfit in South Africa - haven't tried it just yet - but seems like good kit. Much modification required - I'll make posts as I go. The headers were built by SCCA - the Sports Car Club of America - may not fit a standard vehicle - purpose built for the race car in 85-86. Electrodyne has a 4 cyl kit that might work. But not cheap!
    Cheers - Jim
  6. #6
    Join Date
    Sep 2017
    Posts
    2
    Default
    Hopefully you can find here - https://www.icrfq.com/products/ for your car electronic components, it will enable you to locate the required thing you require.
  7. #7
    Join Date
    Aug 2017
    Posts
    5
    Default
    Wondering if anyone has any info on suspension for the gta/alliance/9 I'm looking into lowering it
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
