Results 1 to 5 of 5
Thread: Will an Alliance engine fit in the R 17
  1. #1
    Join Date
    Sep 2018
    Posts
    3
    Default Will an Alliance engine fit in the R 17
    Does anyone have any experience in putting an Alliance Engine into a 17 body. Will the Alliance motor fit and will the 17 gearbox fit on the Alliance engine or would I need the engine and gearbox from the Alliance. Thanks
  2. #2
    Join Date
    Sep 2014
    Location
    Calgary AB
    Posts
    35
    Default
    The Alliance engine/transmission layout is transversely mounted; whereas the 17 is longitudinally mounted. So two very different beasts; a pretty major undertaking.
  3. #3
    Join Date
    Mar 2009
    Posts
    387
    Default
    Hi;
    Not exactly; he can install the alliance ENGINE 1.4 using the R-12 1.3L trainy 4 speeds (that will slap right on the R-17 chasis ),that came in other countries (not the U.S.A.) as the R-12 1.3L model comes already with a small block set up. Some ajustments with the clutch might have to be done . ON the Alliance Trainy you will have to discard it. Thanks
  4. #4
    Join Date
    Sep 2018
    Posts
    3
    Default
    I have the opportunity to accquire an engineless R17, my buddy bought the R17 for the Gordini engine which he plans to put in a Dauphine. I think the R17 is way too good to crush, I asked about the Alliance as he has an Alliance I could rob the engine from. Other than the Alliance engine is there anything else (a slightly more common engine even non Renault) that I could put in the R17. I would really like to save the R17. Thanks
  5. #5
    Join Date
    Sep 2014
    Location
    Calgary AB
    Posts
    35
    Default
    There's been at least one R17 with the Fuego motor swapped into it; how is the body and the rest of the R17?
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
